Synthetic winch rope
Old Jan 28, 2006 | 07:19 PM
sportsman2004's Avatar
Default Synthetic winch rope
I finally got my winch rope. How do I remove the steel cable from the drum on a Warn 2500 winch? Please tell me it can be done without removing the winch....
Old Jan 28, 2006 | 07:54 PM
Slinger's Avatar
Just spool the cable out and unhook the cable end from the slot it is fitted in.
Old Jan 28, 2006 | 08:39 PM
JCDEYO25's Avatar
sportsman2004...
I just respooled mine with Amsteel........I actually took mine winch off just to give me more room...It wasn't too bad taking it off.........I left the wires hooked up, just took all the bolts off because I needed room to get the roller fairlead off......I hope you got a hause fairlead too.......Also be careful when you get to where the old wire rope connects to the drum.....There's a little button which hold the rope to the drum, don't loose it......Also you'll probably have to cut the terminal end off the synthetic rope if it has one, at least I did on mine......You don't need the terminal end for the Warn 2.5.....Just respool it the same way the wire comes off but make sure you do it under tension........I connected the hook to my truck and respool it with the brake on the quad to keep it tight.........I was done completely in about 45 minutes........
John
Old Jan 28, 2006 | 10:22 PM
Thanks JCDEYO25. IT was easier then I thought once I rolled the drum around and seen how it was done. I just put this winch on (after breaking 2 cables and finally the winch. I have a brand new roller fairlead, so I wont have any issues. The hause looks good, but why spend the dough when you don't need to. I need to get my pictures finished so I can post them. Do you got any of your quad? Love to see them.
Old Jan 29, 2006 | 01:46 AM
JCDEYO25's Avatar
sportsman2004..........
I really suggest the hawse fairlead with the synthetic because if you're pulling at an angle, there's a chance that the synthetic can get pinched in the corners.......My roller was basically brand new but I changed it because of that..
John
Old Jan 29, 2006 | 01:52 AM
JCDEYO25's Avatar
spoertman2004.......
I have a bunch of pics but I just gotta figure out how to post them.......
John
Old Jan 29, 2006 | 03:26 AM
IdahoVinnie's Avatar
Since you guys are on the subject, is $70+s/h a good price for 50' of 3/16" Amsteel with a UHMW hausse? SEE HERE
Thanks
Old Jan 29, 2006 | 04:03 AM
scramblerXrated's Avatar
not really, i paid $50 for mine with free shipping.
X
Old Jan 29, 2006 | 05:04 AM
X
Rope and hausse for $50? Wow.
Where did you get it?
Old Jan 29, 2006 | 02:07 PM
JCDEYO25's Avatar
scramblerXrated........
Seems to me that price was just for the rope or was the fairlead included? I searched high and low and found the best price was the site Vinnie was talking about..That's where I got mine......For $79 I think I saw the rope with the aluminum fairlead......
John
