500 knocking
[img]i/expressions/face-icon-small-shocked.gif[/img] Just bought 2 scrambler 500's off of ebay. One is a 2002 and the other is a 2003 with a hot seat performance kit. Both have the same knocking noise from the bottom end. It sounds like it is coming from the crank behind the pull starter. I have never heard o scrambler run. Is this a normal noise since both have the same noise.
That is the famous Polaris clutch knock/ chatter. All Polaris atv's will do it. If you rev it does it go away? These noises are caused by worn buttons in the primary clutch basket causing slop in the clutch.
[img]i/expressions/face-icon-small-cool.gif[/img] Yes the noise does go away when the rpms come up. Thanks. The hot seat performance kit bike is a lot qicker out of the hole. I have not had a chance to ride them yet. Looking forward to riding as soon as we can!!! Thanks again
If you dont get the clutches fixed you will end up with more problems than you want.It will end up knocking the seals out of the lower end of the motor.
Originally posted by: Temper50
I think mine is doing the same. Is the fix easy? What's all involved? A step by step would be nice, [img]i/expressions/face-icon-small-smile.gif[/img].
