Cooling Fan Help Please!!
Old Feb 24, 2006 | 01:04 PM
drewj323's Avatar
Default Cooling Fan Help Please!!
I've got a question for everyone. I've got a 1995 Scrambler and I am just wanting to put a toggle switch on to turn the fan on and off at my leisure. I don't want to rely on the sensor. I've only had the fan come on twice while riding it this winter. Once while pulling a sled pretty hard and once when the radiator started dumping coolant since the drain valve loosened up. How would I wire the toggle switch for this? Please let me know since I am riding this weekend and want to do it before I go out.
Thanks,
Drew
Old Feb 24, 2006 | 01:17 PM
Bradracer18's Avatar
Just find the hot wire out of the fan, and the ground wire....and then wire them into the switch....
Old Feb 24, 2006 | 01:22 PM
drewj323's Avatar
The hot wire coming from the fan and the ground? Then don't I have to run a hot wire to the battery or somewhere else that gets juice from the battery? I think I am understanding what you are saying, but I just want to clarify. I am pretty challenged when it comes to electrical. Thanks
Old Feb 24, 2006 | 01:55 PM
I've never actually done this....I'm just guessing here. But, use a test light, and find the "hot" wire that powers the fan.....if it is before the sensor, you can use it...if not, you'll have to pull power from somewhere else(a pannel or battery).
Old Feb 24, 2006 | 02:01 PM
drewj323's Avatar
I will try that thanks!!! Anyone who has actually tried this, do you have any suggestions?
IMLN
Sep 28, 2015 03:32 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Polaris Side by Sides
Sep 15, 2015 03:33 AM
alzgarvin
Sep 11, 2015 08:53 AM
lancemll88
Sep 5, 2015 03:16 AM
