01'HO Steering
Old Nov 11, 2000 | 09:15 PM
Craig88's Avatar
I was looking to grease the steering stem on my 01"HO Sportsman 500 today and found that there wasn't a lower grease fitting, am I missing anything here? Or is it just that the new setup is a sealed bearing and there is no fitting? Also is there an easier way to grease the upper fitting, it seems to be hidden quite well under the front couling, please don't tell me I have to remove everything in order to get a couple pumps of grease in there.
Old Nov 11, 2000 | 11:02 PM
Farmr123's Avatar
If you crank the bars clear one way or the other, you can get to the top zerk that way. Gives you just enough room (barely). Bottom fitting, I have no idea.
Old Nov 12, 2000 | 04:44 AM
floodrunner's Avatar
You’re right, on the ’01 HOs Polaris eliminated the lower grease zerk on the steering stem. I’m guessing this is because they went to a bearing at the bottom rather than the plastic bushing that used to be there, but that’s just a guess.
Sep 30, 2015 01:37 AM
35dodge
Sep 29, 2015 09:40 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Logan Collins
Sep 5, 2015 08:03 PM
