Predator Oil Question
Time for an oil change.
Question is what do you guys use other then Polaris Oil?
I would like to find an oil thats just as good if not better that doesn't have the expensive polaris brand name on it.
I would like to stick with Synthetic oil so anyone have any good wet clutch synthetic oils they use?
Might try a search on this one.....I know it has been talked about quite a bit on here.
I know people have used mobile and amsoil before......
might also check www.predatorowners.com
Amsoil 0w 40 is a full synthetic oil that works with all wet clutch applications & provides superior protection
I use amsoil ow40 or polaris oil. More important than which brand is changing it often. As long as your using a wetclutch full synethic 0w40 and changing you oil every 8 to 10 hours you will be fine.
