stiff primary
Old Mar 5, 2006 | 08:08 PM
scrammersam's Avatar
Default stiff primary
can too stiff of a primary spring cause any problems?
Old Mar 5, 2006 | 08:50 PM
2manytoys's Avatar
Yes it can cause ALOT of belt slippage and wont shift all the way out. When you go to a stiffer spring you should change the weights to get full shift and better belt grab.
Old Mar 5, 2006 | 11:05 PM
Fastestdad's Avatar
Too stiff of a primary on the engagement poundage will make you'r bike engage much higher in the rpm range. (Maybe good for you maybe bad?) Too stiff on the shiftout will make you'r bike turn much more rpms. Your bike will only make good HP at a certain target rpm range and you wouldnt want you'r engine to turn enough rpm to blow. Give Rick Ritter a call at Ritter Cycle Racing he will get you the right spring , provide free tech help and you'r spring will only probably cost $20-$30. Why monkey with it.
Old Mar 6, 2006 | 12:04 PM
scramblered's Avatar
what spring do you have in right now?
Old Mar 6, 2006 | 08:32 PM
i have a stock one in now, but i have a stiff one from another clutch. the stiff one is black
Ridgerunner665
Sep 15, 2015 01:20 AM
WilliamBos
Sep 6, 2015 10:53 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
