Sputtering - Need help.
Old Mar 6, 2006 | 02:40 PM
Blazer25's Avatar
Default Sputtering - Need help.
Hi - my daughter raced her 1st race of the season. I noticed that in her straight-aways (when she was giving it full throttle) it was sputtering/cutting out a bit off and on. What do I need to adjust to fix that? I am not real familiar with carb adjustments, so I need some opinions. Here is some info that might help:
Polaris Predator 90 w/ 28mm carb kit (140 Main jet, 52 pilot - not sure what the clip is set on) , NEW CDI, Hetrick Pipe(See signature below for more info) (Temperature outside was 40 degrees when she raced.)
Plug looks to be running a bit on the rich side
Any info you can give me would be great!
Old Mar 6, 2006 | 02:46 PM
Bradracer18's Avatar
Take it out, and run it hard(full throttle).....and then immeadiately(spelling?) shut it off(no idle).....check the plug. Tell us then what it reads. If rich still, go down a main jet size.
Old Mar 6, 2006 | 02:55 PM
Blazer25's Avatar
Should I put a new plug in it first?
Old Mar 6, 2006 | 03:10 PM
660Rryder's Avatar
You are running fairly rich. Try dropping down to a 135 main jet and see what happens. If that is to much go to up or down as need but only one size at a time.
ReconBayou
Oct 31, 2022 05:37 PM
EIF
Apr 20, 2017 07:15 PM
Sassinm1
Sep 30, 2015 04:23 AM
Matt123
Sep 29, 2015 01:29 AM
Bernhard
Sep 25, 2015 12:45 PM
