headlight bulb?
Old Mar 13, 2006 | 01:55 AM
polarisbear500's Avatar
Default headlight bulb?
blew one of the two bottom bulbs on my 99 sportsman 500. tried to go to autozone and walmart and ended up with no luck. can i get a replacement anywhere or just polaris or did i not look in the correct areas in the stores? if so, what number bulbs do i need to get? thanks in advance all. PB500
Old Mar 13, 2006 | 01:59 AM
Backinthesaddleagain's Avatar
Check out Grainger:
www.grainger.com
I think they have them.
Good Luck, Bob
Old Mar 13, 2006 | 02:05 AM
i went on there but i dont know what to type in for the numbers for the bulb. if i put "headlight bulb" i still dont know which one is the same as the factory. thanks anyway though
Old Mar 13, 2006 | 08:44 AM
scootergptx's Avatar
Supersock
Hired Gun!
Something else to consider, changing the entire light. You can buy a set of lights with the same wattage, and they should have a bulb that is easy to find replacements for. And those should be cheaper too. The wiring is already done for you.
Old Mar 13, 2006 | 01:56 PM
that is a good idea, thanks, but for now i just need to know where to get a replacement bulb other than polaris. thanks all
Old Mar 13, 2006 | 09:05 PM
I believe that the Grainger stock # is 2F274 for a 37 watt and stock # 1E384 for a 27 watt.
I am not certain if these are actually the ones because I haven't physically checked yet.....but they look identical.
Also....you can get them from Kimpex here:
www.kimpex.com
Good Luck, Bob
Old Mar 15, 2006 | 01:16 AM
Dearlh's Avatar
I would think they are the same as my '03, #894. My wallyworld sells the sylvania 37.5 watt #894 for a little over $6.00. I too thought about upgrading my bumper lights, but the stock ones have the mounting bracket on the side instead of the bottom. Another way Polaris makes it tough to use anything other than stock parts! At least the sylvania bulbs would be a little brighter than the original 27 watters. Hope this helps, check out your local wallyworld!
Old Mar 15, 2006 | 02:12 AM
the 37.5 watt won't hurt melt the mounting housing for the bulbs. i don't know how much hotter that is than the 27 watt.. thanks
Whitelx1
Oct 2, 2015 10:55 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
PrairieDog126
Sep 16, 2015 01:33 PM
