do they have anything for the rear? I need some stiffer springs in the rear b/c I have a huge rack-- and i load it up when i go hunting (ie heavy deer).
I think I read that someone on this four used the MV7 spring on the SP700 or 800 to get a firmer ride. I'm asuming you have the preload maxed out on the rear adjusters. The Only other I can think of is to split the load. IF we all call progressive suspension and ask for a rear spring kit they my consider developing one. Call them and ask the tech line if they have something in the works
i found some rear springs at big buck atv products for $35/ea. I find that reasonable, but I'll call the dealer about the mv7 springs to check pricing as well.
rear springs # 7041519-067 140 lb/in vs the stock 100 lb/in
140 lb/in.
(Standard 100 lb/in)
*ATP 330/500 HO (Standard 40#) see note below
Sportsman 335(Standard 100 lb/in)
Sportsman 400
Sportsman 500
Sportsman 600
Sportsman 700
Sportsman 700 EFI
Xplorer 500
140 lb/in.
Sportsman 400
Sportsman 500
Sportsman 600
Sportsman 700
Sportsman 700 EFI
Xplorer 500
can you measure the free length (fully extended) of your rear shock, with of the shock mounts, and the diameter of the coil itself? I don't know if they changed any over the year models in the rear.
Thanks I'll check it out. I also wonder if Bytor got the Scrambler kit onto his sportsman. Let us know who it went. Thanks
Finally got the springs on yesterday. And guess what? They DO NOT fit. They are about 1" too short. Hopefully Dennis Kirk will take them back.
Bytor. As I said in the other post That sucks. I bought a set off a fourm member. Guess they'll hit e-bay. The srings were shorter by about an inch. Was that with or without the adjustment colar. i did find a listing on the for some SP prings for the 06 bikes.
See link.
https://www.erlandsonperformance.com...TV-polaris.php
See link.
