snowmobile primary spring on a race mod.
Old Mar 14, 2006 | 01:16 PM
badazz400's Avatar
Default snowmobile primary spring on a race mod.
ok guys here we go, i happend to be looking on ebay 2day at primary clutches.
did you know that the almond spring is a primary spring that they use on the 700rmk snowmobile motor.
that made me wonder, what other snowmobile spring kan we use besides the almond for more performance.
polaris makes a stock green/black spring for the 800rmk. i wonder how that would work. probly need some heavy clutch weights.
watch yall think??
ross
Old Mar 14, 2006 | 02:14 PM
conig's Avatar
if you look up primary springs on the pure polaris website it lists all of them and there "polaris listed " spring rate.
you would have to look up snowmobiles individual snowmobiles to see which one took what.
http://www.purepolaris.com/Detail.as...nPage=2&nSet=1
Old Mar 14, 2006 | 04:21 PM
badazz400's Avatar
kooolll!!!!!!!!
im wondern what that almon/red springs like.
anybody using 1?
thanks conig
ross
Old Mar 14, 2006 | 05:48 PM
conig's Avatar
too bad theres not an easy parts look up to specify model, Ive seen it to provide price by part number but not which model the part goes too.
Old Mar 14, 2006 | 06:34 PM
Zbart1's Avatar
see if this helps link
Old Mar 14, 2006 | 07:03 PM
conig's Avatar
yeah I saw that when it was new. in the original posters case he is making the power to justify the stiffer primarys(my sig is way out of date). I use multiple springs depending on what im doing as well.
since HPD uses snowmobile springs and has handy rules for what to look for were just looking for a cheaper alternative then buying marked up springs.
Old Mar 14, 2006 | 09:50 PM
WIscrambler's Avatar
Hey, that's my thread! Basically, what I found out from that thread was the snowmobile primary springs would fit, but you need a great understanding of a PVT clutch to take full advantage of them.
Badazz- I know you were looking for a high engagement for your race mod. You may be able to benefit from the snowmobile spring, but I imagine you'll also need different weights. The shift rate of the snowmobile spring may the too slow for your 400 also. Snowmobiles tend to run a helix in their secondary that has a much steaper ramp than ATV's. You may have trouble finding a helix that will work good since the snowmobile helixes are not interchangeable with the ATV secondary.
Robinhood
Dec 26, 2015 10:28 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
WilliamBos
Sep 6, 2015 10:53 AM
