AWD question
Old Mar 22, 2006 | 12:04 AM
Jimp1's Avatar
Default AWD question
WHEN awd button is engaged[SPORTSMAN 700] the front differential engages when the rear wheel slips. How long does it stay engaged/ Does it disengage as soon as the rear wheel stops slipping? If for example when climbing a steep rock and the rear wheel slips will the front wheels engage and stay engaged until they get in a freewheel mode. Local dealer did a lot of mumbling when I asked him. Thanks JIM
Old Mar 22, 2006 | 12:26 AM
madmatt1971's Avatar
Good question. I have no clue. Call Polaris direct and get the tech line if someone on the fourm does not know the answer. Tell them your dealer could not answer your questions and they'll help you out.
Old Mar 22, 2006 | 10:01 PM
20045SP500HO's Avatar
On my 2004.5 it takes about 5 feet of NO rear wheel slippage to unlock the front ... but I found when rock crawing once locked, i've never had it unlock until back on the trail.
Old Mar 22, 2006 | 10:36 PM
tyler711's Avatar
The front wheels should unlock as soon as the rear tires regain traction (as soon as all four wheels are going the same speed). If it doesn't, you either need a fluid change or front end service. (Fluid change fixes it 90% of the time). On some 04's, there was a recall on the front diff where something went bad and it didn't disengage when it should, not sure though.
In short, it should disengage as soon as you regain traction.
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
