is this to lean????
Old Apr 5, 2006 | 01:18 PM
badazz400's Avatar
Default is this to lean????
right now im runing a oil ratio of 70 to 1 with a 180 main. (on c112 39pwk)
thinking bout changing my main jet to somewhere into the 170's
waya guys think??
thanks ross
Old Apr 5, 2006 | 02:00 PM
CED's Avatar
CED
What does the plug look like.
Old Apr 5, 2006 | 02:06 PM
badazz400's Avatar
right know its a perfect brown, but i like to lean it as much as i could.
gues their isnt but 1 thing to do. change the jets then do a plug check
Old Apr 5, 2006 | 02:09 PM
CED's Avatar
CED
What oil are you using to mix at 70:1 ?
Old Apr 5, 2006 | 02:10 PM
POLARISFREAK's Avatar
Sounds like your jetting is spot on to me. If you want to lean it out a little try running some more oil in it. Your motor will last longer if you run a 40:1 oil mix!
Old Apr 5, 2006 | 02:22 PM
badazz400's Avatar
amzoil 100 to 1.
i used to run 36 to 1. but one day i mixed up a batch of 70 to 1. i ran it and the motor seemed to hit ALOT harder.
i like that ratio. been running it 4 about 5 months now with no motor failure. the compression is still there too!
Old Apr 5, 2006 | 10:28 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
yea it hits harder all right running leaner but beware that you go to lean and burn it down. if it's running a dark bown you could go a little leaner but not much at one time to save your engine. if the tip is at all starting to get grey to white too lean .
Dammar
Apr 20, 2016 06:03 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
bvolks
Sep 13, 2015 12:57 PM
Minimod
Sep 10, 2015 09:20 PM
