Secondary settings on race Mod?
Old Apr 12, 2006 | 11:49 PM
16polaris's Avatar
Default Secondary settings on race Mod?
I have an HPD drag race clutch kit in my bike, I believe the helix is a 44-40, And I have the violet secondary spring in the 2-2 position. Do I have everything setup correct in my secondary?
Thanks!
Old Apr 13, 2006 | 03:27 AM
duneaholic's Avatar
If you are drag racing only then I hear the 1-1 is a good setup.
Old Apr 13, 2006 | 07:36 AM
16polaris's Avatar
Thanks Dune, I will try the 1-1 setting and see if it helps, I will still need to turn it 1/3 turn correct?
Old Apr 13, 2006 | 09:35 AM
CED's Avatar
CED
Yes the 1-1 will be the quickest setting.And you will still have to wind the clutch the same.Do you have the HPD SS buttons,if not it is a very good investment.
Old Apr 13, 2006 | 07:23 PM
16polaris's Avatar
No, I don't have the SS buttons yet but I will add them in the future.
Old Apr 13, 2006 | 10:53 PM
POLARISFREAK's Avatar
It's possible with the 1-1 setting and 44-40 helix that it may bog the engine. The 44-40 will upshift a lot faster than a standard race mod helix therefore 2-2 might work better. Let us know how it comes out. I'm running the 44-36 helix on my race mod with the spring set in 1-1 and it works great!
Old Apr 13, 2006 | 11:16 PM
16polaris's Avatar
That could be what my helix is i'm not sure, I will look at it when I take it out, I will keep you posted on the results as soon as I get it finished.
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Brandon400
Sep 5, 2015 08:44 PM
Logan Collins
Sep 5, 2015 08:03 PM
Sep 1, 2015 01:45 AM
