scrambler 400 help
Old Apr 14, 2006 | 09:23 AM
yamahopper01's Avatar
Default scrambler 400 help
Everytime I get on the gas to go there is a clunking noise coming from somewhere and I cannot find it. Its not the chain, When I let off the gas it stops. I tried hoisting the rearend but it wont clunk it only does it under a load?[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Apr 14, 2006 | 06:43 PM
ftwflh's Avatar
Sounds like the chain inside the tranny is bad.
Old Apr 14, 2006 | 06:57 PM
scrammersam's Avatar
im having the same problem on mine and can not figure it out
Old Apr 15, 2006 | 08:50 AM
Chain inside the tranny?
Old Apr 15, 2006 | 09:37 AM
ftwflh's Avatar
Polaris trannys are actually a CHAINCASE
Old Apr 15, 2006 | 06:14 PM
mudtrail's Avatar
I had the same issue with my 400 scrambler about a year ago. I couldn't figure out where it was coming from or what was making the sound. Come to find out, it was my chain making the noise. My swingarm bolt on the right side had backed out, causing the swingarm to push forward on hard acceleration, thus putting slack in the chain and causing the chain to slip. When I would stop and look at the wheeler, the chain slack would be back to normal. I didn't want to screw anything else up on it, so I quit riding it, took it home and looked it over real well and found the problem. I got some Loctite and re-torqued the swingarm bolt back down, haven't had a problem since.
Old Apr 15, 2006 | 06:48 PM
as far as i knew the 4x4 scramblers have gears inside of the tranny and the 2x4 ones have the chain inside
Old Apr 16, 2006 | 01:15 PM
Mine is a 2x4 I will check swingarm bolt. I hope its not in the tranny, Is it hard to get at if it is?
Old Apr 16, 2006 | 01:54 PM
ftwflh's Avatar
If you are doing the work yourself the tranny chain will be a cheaper fix but will take you about 4hrs the first time you do it.
Old Apr 17, 2006 | 03:06 PM
I will look into it thanks. I was hoping for something simple that i might have overlooked but oh well.lol
