Oil changing
Old Apr 19, 2006 | 10:20 PM
TRX450rKid41's Avatar
Default Oil changing
i am changing the oil on my friends sportsman 700 twin. i am looking for info on how to do it...or any suggestions. This is my fist time doing it on this machine. And what oil/filter should i use also how much. thanks
Old Apr 19, 2006 | 11:13 PM
Sidekickmechanic700's Avatar
warm the engine up a little bit, turn it off. pull the drain plug out from the engine (6mm allen wrench). let it drain all out, then put the plug back in, pull the filter off.
i use a Napa filter, Select 91357, or Gold 1357. for oil i used to use the Polaris 0W40 synthetic. you need 2 quarts of oil to fill it. but keep checking as you add oil, as some oil might not come out, and you don't want to have it over filled. fill it so it is in the safe area on the dipstick.
the oil change is a really easy job, just take your time and you'll be fine.
Old Apr 19, 2006 | 11:21 PM
Lukester's Avatar
Sidekickmechanic700,
Good directions.
For TRX450rKid41 info. To check the oil level after change, he should check level with dip stick screwed in - correct?
Old Apr 19, 2006 | 11:32 PM
with the 700 dipstick, check it by sliding the dipstick in all the way, but do not bend the pressure lever over(the lock system for the dipstick).
Old Apr 23, 2006 | 09:45 PM
is there any other oil i can use for it.....i am not sure were i can get polaris oil.
Old Apr 23, 2006 | 10:11 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
some people use mobil one or amsoil. stay w/ the synthetic grade
Old Apr 23, 2006 | 10:23 PM
right now i'm using fully synthetic valvoline 10w40, seems to be working good.
Old Apr 24, 2006 | 08:10 PM
JCDEYO25's Avatar
I use Mobil One synthetic 0W-40 oil and Purolator Pure One PL 14610 oil filter.......
John
Old Apr 24, 2006 | 08:23 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
for the price differnce, ill just buy the polaris oil myself and thier filter. its just as easy and safe.
Old Apr 24, 2006 | 11:07 PM
cornbread2's Avatar
Any good name brand Synthetic oil will work just fine and it is as good or most of the time better than the Polaris oil.
I reccomend Castrol Syntec 5w50.
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
