scrambler serious electrical issue
Old Apr 29, 2006 | 08:30 PM
mr2strokebanshee's Avatar
Default scrambler serious electrical issue
I am getting very frustrated with my scrambler. Here is the problem the machines electric start does not work, if it is pullstarted it will run but the lights dont work or the 4x4. I have replaced the starter solenoid, battery, voltage regulator, stator, and left handlebar switch.
If you jump the starter solenoid it will turn over and start but no lights or 4x4. Im lost any help would be greatly appreciated.
Old Apr 29, 2006 | 11:22 PM
ftwflh's Avatar
Change ALL the light bulbs or at least check them and make sure the solinoid is wired right.No broken wires.
Old Apr 30, 2006 | 01:25 AM
IdahoVinnie's Avatar
Use a testlight or a voltmeter to see if you are getting the proper signal at the solonoid (small wire). If you aren't, it's probably either a fuse, wiring, ignition switch, or the start switch.
Let us know.
Old Apr 30, 2006 | 10:28 AM
I will give it a try thanks.
Old Apr 30, 2006 | 09:29 PM
danwuz's Avatar
Did you have any luck? I have a very similar problem with my 1999 500 Sportsman. It will start with the recoil in a couple pulls, but the starter can crank over until the battery is dead and never get a pop. Could use some advice if things work out for you.
Old May 1, 2006 | 05:57 PM
Russ136's Avatar
I fixed a similar problem with a friend of mine Honda EX 300. It was hard to find but it wound up being a bad connection in a plug in connector. Also check for a bad ground from the battery. Or even a bad battery cable.
skinnyr6
Aug 25, 2023 02:18 AM
maxjung
Jul 15, 2015 11:59 PM
maxjung
Jul 13, 2015 05:11 PM
Unzzy66
Jul 11, 2015 10:01 PM
Chocobamofo
Jul 10, 2015 07:46 PM
