Are all pipes created equal??? Scrambler 500
Old May 12, 2006 | 12:45 PM
stvreilly's Avatar
Default Are all pipes created equal??? Scrambler 500
Gentlemen, I have an 05 scrambler that I would like to put a pipe on and probably jet. I have heard many good things about the product "dial a jet". apparently it makes adjustments quite easy (good for me as I am not mechanically inclined) From what I gather, the full exhaust provides more power gains than a slip on. Is this correct? Secondly, Are there large differences in performance from one exhaust to another? If not, perhaps I should I just let my dealer pick one out? I am planning on having my dealer do the work, to avoid voiding my extended warranty. Currently my scrambler is stock except for a clutch kit. Any advice would be appreciated.....
Old May 12, 2006 | 04:57 PM
ftwflh's Avatar
Any good brand of pipe for the 500 is ok best to stay with Aaen,White Bros,FMF for the slip ons but the full systems from HPD or HSP offer a slight more gain but not enough for me to justify the extra cash.As for jetting go with the HPD airbox mod kit and a Dial-a-jet.
Old May 12, 2006 | 05:14 PM
theCATman's Avatar
White Bros. E-Series is what I run on my 500 & love it. The ability to adjust the sound & power level is a huge plus.
Old May 15, 2006 | 11:03 AM
Speedwerx's Avatar
Stvreilly, I'm from HSP our kit full exhaust kit for the 500 scrambler comes with proper jetting, we also offer a slip on but jetting changes are not needed with that. We do suggest making cluthcing changes wit our kit as well you shoudl also know that a cluthc kit for a stk. bike can be different form a biek with a pipe or other mods, You may not need to get a new kit entirly but you might have to change a spring or weights. I see your from NJ and the dial a jet may work but you will still have to get a base line jettign set-up for what ever pipe kit you go with. We mainly use the dial a jet for riders who ride in a wide range of elevation for example 0'-5000'. For you I would not suggest getting the dial a jet becasue once you have you base line you shouldn't need to re-jet unless riding in the winter time bellow 30 degrees or @ a high elevation.
Old Jul 22, 2006 | 03:53 PM
pimpmyatv's Avatar
if you are looking for somthing that will make some noise go with the White Bros and thay look nice to i had the cops asking me y i was makeing so much noise it was like 7:30 in the morning and me and some frainds waer racing and i was told i was desterbing the pess so i had to sell it and i got the fmf pipe it is much quiter
chingchangchong
Aug 7, 2022 11:36 AM
exmotocrosser
Sep 13, 2019 06:12 AM
mrtidy
Feb 3, 2016 05:00 PM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
