Head bolt....leaking coolant
Old May 18, 2006 | 01:44 PM
94sport400L's Avatar
Default Head bolt....leaking coolant
Didnt put on new head bolts - didnt think i would need too.
Old May 18, 2006 | 04:07 PM
conig's Avatar
ive never bought new ones, no problems so far.
Old May 18, 2006 | 04:20 PM
WIscrambler's Avatar
I have also never replaced the head bolts...never had a problem either. I did have a problem with a leaking aftermarket head gasket though. It only lasted about 3 hours! I replaced with an OEM gasket and haven't had a problem since. The Polaris gasket actually feels a little heavier duty than the aftermarket gasket I had.
Old May 18, 2006 | 04:46 PM
I'm going to go ahead and just order a polaris head gasket - seems to be the best thing to do. Just sucks that i cant locate one at a nearby polaris dealer. Wanted to go ride this weekend.
Old May 18, 2006 | 05:32 PM
  #15
cornbread2's Avatar
Originally posted by: MaineMudder3
Did you put new headbolts? Just as in automotive applications, once a headbolt is properly torqued to spec either foot pounds then twist-turn torque or just foot pounds, it is stretched to its elastic limit and therfore should be replaced if ever taken out to replace such a thing as the head gasket. More then likely the bolt or bolts won't properly torque the second time.
The 400L does not have "head bolts". It has studs and nuts and they do not need to be replaced unless damaged.
Old May 18, 2006 | 05:34 PM
  #16
cornbread2's Avatar
Are you sure the coolant is not leaking from the coolant vent screw on top of the head instead of a head bolt?
Old May 18, 2006 | 05:54 PM
  #17
Its leaking from the actual nut, not the coolant vent screw. The one closest to the coolant sensor.
Old May 18, 2006 | 07:28 PM
  #18
MaineMudder3's Avatar
I'm a four-stroke man by nature..my bad didn't know!
Old May 30, 2006 | 03:32 PM
  #19
Just wanted to say thenks for the help guys. Ended up getting the polaris head gasket. Put it back together and only had a chance to run it for 10-15 minutes. Didnt see any leaks, so hopefully it'll stay that way.
1ArmBandit
55
Oct 14, 2015 09:03 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Sep 23, 2015 06:23 AM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
