Battery Life
Old May 16, 2006 | 04:56 PM
Chukarhntr's Avatar
Default Battery Life
I seem to be going through a lot of batteries with my 04 Sportsman 500. what kind of battery life is everyone getting?
Old May 16, 2006 | 05:53 PM
JjEjFjf's Avatar
What do you call alot?
Old May 16, 2006 | 05:57 PM
Chukarhntr's Avatar
I seem to replace it about once a year. Isn't that too often?
Old May 16, 2006 | 06:05 PM
JjEjFjf's Avatar
Old May 16, 2006 | 07:22 PM
Kerbbirds's Avatar
Does it sit outside in the cold all the time? Cold is real hard on batteries,especially if they are not charged regularly. My 97 425 is on its third battery, my 03 700 still has the original.
Old May 16, 2006 | 07:29 PM
Chukarhntr's Avatar
I keep it in my back shop (unheated, uninsulated), but I also start it up periodically during the winter. I had it running about a month ago, and now I can't even get the starter to click.
Old May 16, 2006 | 07:37 PM
20045SP500HO's Avatar
One every two years... Maybe you have a short somewhere.
Old May 16, 2006 | 07:59 PM
Kerbbirds's Avatar
Unless you ride it for an hour or more your probably not gettig the battery fully charged, try one of those battery tenders, they are a little trickle charger you hook up when not in use.
mistertinker's Avatar
get one these and put a two wire flat plug coming off your battery.battery charger
charger
this is another one. if you use one of these your battery will always be fully charged and most likely last 2 or 3 years.
Old May 17, 2006 | 07:29 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
my wifes batt. in her t. blazer is 5 yrs old and finally replaced it. my 500 was 3 yrs old and never had a problem w/ it. they both sit in a unheated garage w/out starting them at all during the winter. just make sure the acid is full in the batt.a nd their charged good.
