Where to buy?
Old Jun 19, 2006 | 12:06 AM
Benjio's Avatar
Default Where to buy?
I use Royal Purple 75W-90 in the trans. on the Harley, which is a 94 Ultra Classic. I just had the engine rebuilt and am using Mobil 1 V-Twin oil in it. I plan on using the same Royal Purple in the gear case and trans. on the Polaris. Any reason I shoudn't?
Old Jun 19, 2006 | 12:23 AM
ftwflh's Avatar
I wouldnt use anything but Polaris AGL chaincase lube.The Polaris transmission is really a chain case and needs a light wieght synthetic lube.The best way to discribe the tranny is it is simarlar to the old GM 4x4 transfer cases.
Old Jun 19, 2006 | 09:00 AM
Benjio's Avatar
Well, it does make sense to use what they recommend. After all most likely this will only be done once a year anyway. I believe that is sound advice.
Thanks
