1998 Scrambler Help, Went riding, keeps overheating
ncriderforks that would be great for a torque down pattern and maybe the torques if you can get them. Kinda odd how the gaskets differ, Both have aluminum cores and a gasket material yet the quality of the material pribably differs greatly, Brian
TORQUE IS AS FOLLOWS
Torque all bolts evenly in criss cross pattern
1) Torque bolts to 22 ft lbs.
2) Torque bolts to 51 ft lbs.
3) Loosen bolts evenly 180 degrees. (1/2 turn)
4) Loosen bolts again 180 degrees. (1/2 turn)
5) torque bolts to 11 ft lbs.
6) Tighten bolts 90 degrees
7) Finally, tighten another 90 degrees.
Install 2 6mm bolts and tighten to 6 ft lbs.
Damn i bet if I did that the gasket wouldnt have leaked, All I did was tighten it twice through and that was it. Thanks alot man! that is great info! Brian
#16
ok, the front tab should be facing the front correct? But it could also be on worng because the left side might have to where the right side is. I put it on the way i thought it was when I seen it sitting on it, thanks, Brian
