What's your ideal quad??
Old Nov 27, 2000 | 11:03 AM
Farmr123's Avatar
Either an all-shaft drive Xplorer 400 or possibly a 500 Mag HO. Maybe take off some unneeded weight.
I have bigger dreams, but figure I ought to be realistic.
Old Nov 27, 2000 | 01:15 PM
ledebuhr1's Avatar
i want a sp700 with an accurate fuel gage, a temp gage, heated hand warmers, and heated seat. then i would put mudrunners on it with itp magnums rims.
Polaris are u listening??????
i know u read this
later
jon
Old Nov 27, 2000 | 02:15 PM
Farmr123's Avatar
Yes, yes, A fuel guage and temp guage. Nothing fancy. The fuel guage could be as simple as a window in the plastic to see the fuel level inside. It wouldn't be hard to do, the tank is already plastic and translucent, just give us a window.
A temp guage would be nice, too, for those of us who like to watch that sort of thing. Why not make it a dealer add on accessory at a reasonable price?
Old Nov 27, 2000 | 02:47 PM
Bill.Ciliberti's Avatar
Farmr123,
your gas gauge prayers have been answered,for 18 dollars,Polaris does make a replaceable gas cap that has a built in fuel gauge.I know,I have one on the Xplorer,
Bill
Old Nov 27, 2000 | 04:35 PM
  #15
jeepin's Avatar
My idea qaud would be a 500 cc 2 stroke with about 15 inches of wheel travel,Chromoly frame,carbonfiber beadlocks,18 inch rear tires that never go flat,20 inch front tires that never go flat,A 9000 pound winch that only weighed like 2 pounds,carbon fiber steering stem and spindles,dual caliper front brakes (2 calipers on each side,2 caliper rear brakes,carbon fiber exhaust,Runs on 87 octane pump gas,150 horse,Suspension so good you can do a 80 foot double siting down!
But for now the qaud I own is my dream qaud.
86 trx250r wiseco .020 piston,boyesen reeds,porting by p.m.s,Dg alloy series nerfs,JD performance +2 A-arms,durablue eliminator 2+2 adjustable width axle,durablue posi loc axle nut,white bro's white power shocks with adjustable res's all the way around,PEP easy pull clutch perch,FMF gold series fatty pipe,power core 2 silencer,braking brake pads,fastline braided steel brake lines,uni filter,nac's casesaver,motion pro clutch cable,pro design kill switch,18/11/8 holeshot mx's on mitchell .190's,21/7/10 holeshots on ITP .190 wide off-sets
www.geocities.com/atvracerman1/picpage1.html
Old Nov 27, 2000 | 04:36 PM
  #16
ledebuhr1's Avatar
bill
do u find the gage accurate?? does the needle move alot when u are riding on rough ground??
we had one like that in our lawn tractor and it was ok but the needle moved around alot as the gas sloshed around in the tank.
i was hoping for an electric fuel gage like the polaris sleds have.
later
jon
Old Nov 27, 2000 | 05:51 PM
  #17
Sharpe1's Avatar
Give me HPd's hopped up race ready Sport with the completely customized racing frame that was in ATV sport awhile back with 4wheel drive on it and I'd be one happy camper!
Old Nov 28, 2000 | 09:40 AM
  #18
Farmr123's Avatar
Thanks, Bill.
Old Nov 28, 2000 | 09:48 AM
  #19
ledebuhr,
The gauge is not as accurate as Id like it to be,but its pretty close.It has more fuel in the tank than it reads,so I have adjusted myself to reading it like that.The needle does move a little on harsher terrain,but its not real bad.For 18 dollars,its a DEFINATE buy,
Bill
Old Dec 2, 2000 | 09:31 PM
  #20
rangerchet's Avatar
My ideal quad would be an xpedition 625 cc with 8 gears. And re-designed so I could put 28 inch mudbugs on it. It would have sp500 like clearance to start with. It would be as tough as the current
xpeditions. It would let me know what gear I was in. It would have a better front end bumper set up
to more fully protect the rad and slide over obsticals. so tell polaris to make it for me! rangerchet
