EBS question
Old Jun 26, 2006 | 08:39 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default EBS question
if you look at your primary it has a groved brushing in between the sheeves. that is the ebs part. if your belt is sitting up about 1/8" in the secondary clutch and the sides arent all groved out and burnt it should be ok.
Zbart1's Avatar
Well to be perfectly honest I don’t know if you belt is shot!
I am just going by my experience with the Polaris clutching, you stated that the engine slowed you down a lot better when new then it does now. My thoughts are that as your belt wears it rides lower in the primary as well as the secondary clutch’s therefore giving it less mechanical leverage (or gear ratio) to slow your engine resulting in it not being as effective as it was when it was new.
Now I have not seen your machine and blanket statements like this are a bad idea on my part.
Also since you said there is a noise coming from that area it seems you need to open it up and check the system out …….springs , weights, belt wear and buttons.
Also check the primary clutch sheave faces as these tend to wear out.
Old Jun 26, 2006 | 11:00 PM
TBJAY's Avatar
this atv is only a month old there better not be anything worn on it
the rattle seems like it is coming from the rear somewere not so much the clutch cover
i was wondering if it could be the chain being to loose because when i hit the throttle it goes away and the dealer said that once the chain stretches it may need to be tightened
i just dont know how to check for to much slack
Old Jul 10, 2006 | 01:09 AM
TBJAY's Avatar
well i looked at it today and to be honest i have no clue
the rear bigger pulley seems to have a slit under the belt but not big enough for the belt to fit in
im not sure what to look at to see if there is ebs or not
the engine slows me down until i am at a complete stop then the quad will drift free for a couple seconds then the engine kicks in and stops it from gaining speed
Old Jul 10, 2006 | 01:30 AM
  #15
duffus's Avatar
can you measure the width of the belt with calipers?
Old Jul 10, 2006 | 12:09 PM
  #16
TBJAY's Avatar
no but the belt iswider than a car belt (serpentine)
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
