predator front noise
Old Aug 8, 2006 | 04:53 PM
bullbarrel's Avatar
Default predator front noise
I you are sitting on the atv its the front left shock when you turn the atv it makes a poping noise and i can sit and go in a circle and it will pop a lot any idea what the problem is thanks
Old Aug 8, 2006 | 05:17 PM
2001Bansheeboy's Avatar
I had the same problem when I lowered my front end. The problem is that the springs are coming unseated and then popping back into place, lift up the front of your quad and see if there is any room between the springs and retainer rings, if there is just tighten them up until they are flush with the springs, this will fix the noise if this is your problem.
Old Aug 8, 2006 | 05:51 PM
bullbarrel's Avatar
new info guys me and my dad went out and messed with it come to mfnd out the noise is cumming from inside the tire any ideas thanks
Old Aug 8, 2006 | 06:01 PM
Webopper's Avatar
Can't help ya with the tire, but no freakin way you are from Ladoga...that is just too bizzare man, I grew up there. Went to SouthMont High...Go Mounties!!!
Old Aug 9, 2006 | 06:38 PM
Bradracer18's Avatar
If actually coming from the "tire area".........you might check the lugs......make sure the hub nut is tightened appropriately.......uhh could also be the bearings in the hub.......make sure stuff around that tire is tight(brake, tie rod, etc).........I'm still betting on the spring as said above.......
Old Aug 11, 2006 | 10:54 PM
bullbarrel's Avatar
He guys ended up finding the problem it was the bearings going to get new ones tommorw thanks for the help guys. thanks
1966F100
Jul 24, 2015 02:17 PM
1966F100
Jul 14, 2015 12:19 PM
1966F100
Jul 12, 2015 03:08 AM
steveo612
Jul 11, 2015 08:35 AM
D-Hagz
Jul 4, 2015 02:19 AM
