cams or p&p?
Old Aug 21, 2006 | 07:57 PM
daPREDATOR's Avatar
Default cams or p&p?
well now that i got some cash to spend on my bike what would be a better mod a set of cam or a good p&p?
Old Aug 21, 2006 | 08:14 PM
spyder6's Avatar
www.nicholascycle.com
578 motor gets my vote
Old Aug 22, 2006 | 12:39 AM
daPREDATOR's Avatar
yea i was look at da 558 from hp and da 578 from nicholas and also da 600 stroker from falcon which one would be better for drag bike?
Old Aug 22, 2006 | 08:21 AM
spyder6's Avatar
the nicholas cycle motors are the best (and by the way, its The, not Da)
Old Aug 22, 2006 | 07:53 PM
Speedwerx's Avatar
If your serious at all about draging e-mail Doug @ nicholas asap. Hes' the man when it comes to full blow race predator motors. If you want somthing safe reliable to just wax your buddy then look at our 600 bolt on kits. www.speedwerx.com
Old Aug 22, 2006 | 08:07 PM
daPREDATOR's Avatar
yea just to beat some 450s at the drag strip and some buddies....... on the stroker kits do you have to use race gas? only if you get high comp. piston right? cause i dont want to have to run race gas
Old Aug 22, 2006 | 08:39 PM
spyder6's Avatar
im pretty sure race gas is only neccisary when useing a 13:1 or higher compression piston. 12:1 is 98 octane
Old Aug 22, 2006 | 08:43 PM
daPREDATOR's Avatar
12.1 below is ok to use pump gas? does nicholas offer a 12.1 piston for there 578 kit? also how reliable is the 578?
Old Aug 23, 2006 | 11:44 AM
Speedwerx's Avatar
Our 600 kit is not a stroker its a top end kit cyl. gaskets, piston 11:1 or 12.5:1. It is 100% reliable probably better than stock due to billet cyl. and design of cyl. sleeve.
Old Aug 23, 2006 | 03:54 PM
daPREDATOR's Avatar
yea i've seen your guys 600 bore kit you guys offer it both race gas or pump gas right? is there any performance difference? also have you guys dynoed the 600 kit?
