k&n filter ?
Old Sep 16, 2006 | 02:23 PM
shells's Avatar
Default k&n filter ?
i see a lot of people are running k&n filters , do they help something over stock filters and what would that bee also what is the cost for a sp.800
Old Sep 16, 2006 | 04:05 PM
YFZracer12's Avatar
Yes they help over stock because they are letting more air flow and more air flo=more POWER but u aslo have to rejet if u are running a carb the EFI models should adjust to them
Old Sep 16, 2006 | 04:43 PM
Ganggreen's Avatar
With that more air flow comes the more expense of dirt/grit in the engine.
Old Sep 16, 2006 | 08:29 PM
v2rider's Avatar
No you DONT have to rejet for just a K&N filter.
Old Sep 16, 2006 | 09:36 PM
800stealth's Avatar
the K&N filter will help the bike breath a little easier and you obviously don't have to buy any more filters, but you will not notice any power gains. The biggest gain i got was with the new exhaust, filters up here in Alberta are around $60
Old Sep 16, 2006 | 09:37 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
k&n allows more dust and dirt to go in the engine. i dont beleave you would gain much or any power w/ just a kn w/out a pipe to go w/ it. more air in and not letting more exhaust out (w/out a pipe) is kinda of useless.
Old Sep 16, 2006 | 10:04 PM
greenscreaminv's Avatar
K&N filters definately help over stock filters. The power gains you get will not be arm streatching, but on most machines, a little goes a long ways. I have ran my kfx with a K&N filter in very dusty conditions as well as sand dunes and have NEVER found any dust or sand inside the filter. The air box can have a layer of sand inside and when I take out the filter out for cleaning, the box under the filter looks bandnew. With a K&N you never have to buy another flimsy foam filter and to clean you simply spray on a cleaning solution and rinse with water. Let the filter air dry and spray on some K&N oil. Done. After running a K&N filter, I wouldn't run anything else.
Old Sep 16, 2006 | 10:39 PM
ftwflh's Avatar
IMO a K&N is a very good filter but you need to run a prefilter and carry a spare.But if you ride wet conditions a UNI filter is better because when you sink the quad the UNI can be wrung out and put back in.( then reoiled when you get to the truck)
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
