330 boss jet question
Old Sep 29, 2006 | 07:00 AM
collins84's Avatar
Default 330 boss jet question
Aight going today to pick up a k&N filter for my boss and wanted to know if I should rejet and if I should what is the best jet to go with. Also if I get the filter and want to put some holes in the top of airbox what jet should I go with then just trying to get some better performance not much info on the thread earlier. Any help would be appreciated.
Old Sep 29, 2006 | 07:08 PM
speedy63's Avatar
You shouldn't need to rejet if you are just getting the filter. If you put an aftermarket exhaust on then you will need too. The boss I had actually ran better with no holes in the airbox , even after rejetting for it, so I plugged the holes back up and went back to the stock jetting. It may be different for you though as I ride in a lot of high altitude areas.
Make sure you get the outer wear for the filter though or you will be cleaning it often.
Old Sep 30, 2006 | 12:43 AM
Lukester's Avatar
Open up my pictures and read the introduction on the top. I list the size jet and mod.'s that work for me at 500' above sea level. I hope it helps.
wendal
Oct 31, 2017 03:31 AM
oliveiracarlos
19
Nov 11, 2015 05:49 AM
bigred20653
Oct 2, 2015 10:05 AM
craacker
Sep 9, 2015 04:32 AM
Elkaholic
Sep 6, 2015 02:44 PM
