400 scrambler 4x4 problem
Old Sep 29, 2006 | 10:37 AM
jmw132001's Avatar
Default 400 scrambler 4x4 problem
i have a 1996 400 4x4 atv. the other day i went in the mud and had it in AWD mode. well all four wheels started to spin so i thought i would just back up and take another way. well when i put it in nuetral my AWD light went out. so i thought maybe that is the way it works. well i put it in reverse and still no awd light. so i gave it the gas and sure enough only the 2 rear tires will spin. but once you throw it in drive the awd light comes on and all 4 tires spin. anybody know what the heck the problem would be????? Thanks
Old Sep 29, 2006 | 10:49 AM
PGTDriver's Avatar
On mine you have to push overdrive in reverse for the 4x4 to work
Old Sep 29, 2006 | 11:24 AM
06LimitedPred's Avatar
Same with my Hawkeye, in reverse the override button has to be pushed for AWD to engage. Had me concerned the first time it happened, then i figured it out lol
Old Sep 29, 2006 | 02:40 PM
jmw132001's Avatar
ok, thanks alot. i will give that a try and see what happens. i was like what the heck when it wouldn't work. couldn't figure it out. this time i will hit the override and see if she goes. I will let you know what happens. Thanks
Old Sep 29, 2006 | 03:01 PM
jmw132001's Avatar
ok, i tried the override button and that did it. all 4 wheels spun. how long does it take for the front hubs to kick in? when i put it in reverse all 4 wheels spun right off but then i swicthed to drive and the 2 rear and the front left spun, then finally the front left clicked in. is that normal on these? Thanks
Old Sep 29, 2006 | 11:34 PM
Whitedog's Avatar
Have you changed the hub fluid lately? Sometimes low, or dirty fluid will cause crazy actions out of the hubs. They take type f trans fluid.
Old Sep 30, 2006 | 04:36 AM
mrtwostroke's Avatar
generally it is instant. check this sit out and follow the directions to eliminate the need to push the button. http://www.highlifter.com/forum/3_li...1385581/tm.htm.
just follow the directions pretty simple
Old Sep 30, 2006 | 10:53 AM
PGTDriver's Avatar
Ya i would definatly change the hub fluid if you havn't done that. I think my quart of hub fluid was like 9.99 from the polaris dealer. CHanging the fluid just might solve your problem. Good luck
Cole Hadden
Jun 15, 2025 09:05 AM
1000gade
Jul 16, 2015 10:48 AM
maxjung
Jul 15, 2015 11:59 PM
maxjung
Jul 14, 2015 12:29 PM
maxjung
Jul 13, 2015 05:11 PM
