Help few questions
Old Sep 29, 2006 | 09:22 PM
marksduramax's Avatar
Default Help few questions
I have a 99 polaris scrambler500 4x4 HO. If i leave it sittin for about a week or two without startin it - it will not start. The only way i can get it started is to spray starter fluid in the carb. then its still a pain in the butt to get started. sometimes it back fires... after i get it runnin it runs fine other then when i turn it off it leaks gas out the bowl on the carb - what could this be? please any one with info please share
I just replaced float needle and seat it helped it but at the bottom of the bowl where the over flow hose is it leaks out of that not bad just when you rev it up... i dont know that this could be i have cleaned the carb Any one know where to start lookin?
Old Sep 29, 2006 | 10:12 PM
miniexcavator's Avatar
perhaps the float is cracked and full of gas
Old Sep 30, 2006 | 07:10 AM
Would that make it come out the over flow just when you rev it up only time it dose it now??
Old Oct 1, 2006 | 01:49 AM
So know one knows what this could be? The screw at the bowl could that be my problem???
Old Oct 1, 2006 | 02:10 AM
scramblerXrated's Avatar
are you shutting of your fuel while storing it? if so, it sounds like the carb is leaking out and draining the bowl. this will cause a problem while starting because theres no fuel in the bowl when you go to start it. hence using the starting fluid would compensate.
i have a few ideas...
-since you just replaced the needle and seat, check the manual and make sure that the floats and needle are properly adjusted.
- check the gasket beteween the bowl and carb body.
- make sure that the drain screw is tight, if not it will drain the bowl over time, a few weeks seems about right to leak it all out.
- make sure the main jet access bolt/plug is seated properly on the bottm of the bowl. theres an o ring on the inside of this bolt.
- fuel pump malfunctioning?
- fuel filter clogged?
hope this helps....
X
Old Oct 2, 2006 | 09:14 PM
Kerbbirds's Avatar
If it's got a new needle and seat then the float level is to high or the float has a hole in it , is the crankcase full of gas? This would explain the hard starting.
Old Oct 2, 2006 | 10:54 PM
Found the problm my bowl was cracked i got j/b weld on it now... I bout a used bowl to day at the dealer put it on and it would not idiel put the old bowl back on and runs fine other then gas comein out of the bottom... why wouldint it run with the new bowl i can not figer that one out.
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
