How do you change the left side spark plug 800 efi
Old Oct 1, 2006 | 08:02 PM
Madcap's Avatar
Default How do you change the left side spark plug 800 efi
Got the right side no problem but the left i can bearly see never mind get a wrench in there.
Old Oct 1, 2006 | 08:34 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
havent had to do mine yet. taking the side panel off doesnt give any better access?
Old Oct 2, 2006 | 12:01 AM
JjEjFjf's Avatar
I think i remember reading something about having to take the gas tank off to get to it.
Old Oct 2, 2006 | 04:52 AM
UTU's Avatar
UTU
its a pain but you can do it with 3/8 drive and socket. side panel off. I put the socket on the plug first and just slipped the ratchet on. its hard to but can be done
Old Oct 2, 2006 | 09:34 AM
Madcap's Avatar
Did you get both plugs from the right side?
Old Oct 2, 2006 | 10:17 AM
UTU's Avatar
UTU
left side for left,right side for right. its tight but doable
Old Oct 2, 2006 | 10:57 AM
Madcap's Avatar
Did you have to remove the clutch breather?
Old Oct 2, 2006 | 11:02 AM
motoman67's Avatar
utu is right you can use a 3/8 ratchet and socket or the plug wrench in you tool kit its a pain but the side panel is the only thing you need to remove
Old Oct 2, 2006 | 09:00 PM
BigDog800EFI's Avatar
The plug wrench that is in your kit is the best way. Be carfull that the hole is not full of mud/dirt before you take it out.
Old Oct 2, 2006 | 09:18 PM
Kerbbirds's Avatar
I did my 700 from the right side, used the wrench that came with it and a wratcheting wrench on the top of the socket, worked pretty good but it is a pain.
