pull crank
Old Oct 3, 2006 | 08:28 AM
rtw20's Avatar
Default pull crank
will the pull crank work if stator is bad? Elect start will not work and no lights but pull crank works everytime.
97 sportsman 500
Old Oct 3, 2006 | 08:33 AM
MINIQUAD97's Avatar
Default pull crank
the stator is one of the parts that have to work before the engine will run so the your stator is good
Old Oct 5, 2006 | 09:54 PM
rtw20's Avatar
Default pull crank
thank you, i replaced battery and all ok.
Old Oct 5, 2006 | 09:58 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default pull crank
rtw20, did your lights work after you pulled started it? i was just wondering if the charging system was making enough juice to make everything work.
Old Oct 5, 2006 | 10:14 PM
rtw20's Avatar
Default pull crank
no, the lights did not work after pull starting atv.
robert301972robert
Aug 30, 2015 11:34 AM
Hatrackr
1) Engine problems..
Aug 11, 2015 09:03 PM
WesTech
11
Aug 11, 2015 07:55 AM
Polarisman1123
Aug 3, 2015 02:08 PM
