oil injection trail boss
Old Nov 23, 2006 | 05:49 PM
tonnor's Avatar
Default oil injection trail boss
anyone out there have the answer to my problem i dont believe i am getting oil to the motor and since our other bikes run premix i figure to premix on the wifes 1996 trail boss now the question do i have to change anything or eliminate anything or can i just drain the oil from the oil injection and premix the fuel also i plan on running amsoil 100 to 1 wil this work with out any problems ride set for friday noon so i need to figure this out soon thanks again
Old Nov 23, 2006 | 05:59 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if you do a serch on this you'll find alot of info. most run 40 to 1 i beleave and usually they diaable the oil pump. personally i wouldnt disable it.
Old Nov 23, 2006 | 06:13 PM
tonnor's Avatar
stick with me here if i drain the injector oil and just premix will this hurt anything i see the sell block offs but do i need this what if i put oil in the tank but remove the line to the cyclinder this would still put oil to the pump but not into the cyclinder my problem is when i remove the line to the cyclinder i am not getting a steady drip so i want to premix but i d0nt want to ruin anything
oliveiracarlos
19
Nov 11, 2015 05:49 AM
craacker
Sep 9, 2015 04:32 AM
Elkaholic
Sep 6, 2015 02:44 PM
JakeXBL
Sep 5, 2015 01:08 PM
Canamaniac!
Sep 4, 2015 06:44 PM
