Scrambler 500 coolant overflow problem
Old Dec 18, 2006 | 08:03 PM
BigBlueScrammy's Avatar
Default Scrambler 500 coolant overflow problem
OEM. Have the cyclinder and head checked for warpage.
Old Dec 18, 2006 | 08:11 PM
03scrambler500's Avatar
Ok OEM it is. Once again thank you for all the help! Can't wait to go out and not get a leg full of coolant! Thanks
Jason
Old Dec 28, 2006 | 12:38 AM
STARKSREBEL's Avatar
it sounds like the head gasket is blown to me as well.did you let all the trapped air out of the head with the bleed screw on the head?if not try this first.if you replace the head gasket use some copper never seaz on both sides this will help it seat better.
Old Dec 28, 2006 | 11:42 PM
I got a new head gasket in and it hasn't done this since. Before I put the new gasket in I did a coolant system pressure test and a combustion gas check and each test showed that there was a leak. I really appriciated all of the support!!!
Jason
Cole Hadden
Jun 15, 2025 09:05 AM
SDR-II
Sep 29, 2015 01:06 AM
1000gade
Jul 16, 2015 10:48 AM
maxjung
Jul 13, 2015 05:11 PM
Coryco
Jul 6, 2015 07:30 PM
