scrambler 4x4 problem
Old Jan 1, 2007 | 05:13 PM
01vic99's Avatar
Default scrambler 4x4 problem
i noticed today while plowing snow that my 4x4 doesn't engage in reverse. My override switch seems to be functioning properly when used in forward gear. when used in forward it causes the yellow reverse light to come on. The other odd thing that i think may be related is that when i put the bike into reverse, the nuetral light doesnt go out and when i hit the override button in reverse it doesn't seem to do anything. any ideas what could be the problem?
Old Jan 1, 2007 | 05:30 PM
Freedom500's Avatar
Most likely the switch on the transmission needs cleaned or replaced.
Old Jan 1, 2007 | 06:02 PM
scgmag325's Avatar
I noticed the same thing with my magnum. On mine 4x4 will engage if you use the reverse override button, so try that.
Old Jan 1, 2007 | 06:04 PM
scgmag325's Avatar
sorry about my last reply... i guess i didn't read the problem fully. i agree with freedom 500, i think the switch on the tranny should be cleaned
Old Jan 1, 2007 | 06:06 PM
scrammersam's Avatar
some electical current musnt be flowin properly
Old Jan 1, 2007 | 10:02 PM
STARKSREBEL's Avatar
if when you put your bike in reverse and the reverse light does not light up then you need to adjust the shifter rods or check and make sure there not bent.if the reverse light does not come on it will not lock in 4x4.if your neutral light is staying on in reverse the shifter rod is not engauging properly.
Old Jan 2, 2007 | 08:31 PM
01vic99's Avatar
just checked the linkage it seems to be engaging the same as my other machine does. I adjusted the linkage just to make sure the shifter was not hitting on the plastic and now it seems its going in as far as it can. but i still have no reverse light. as for the switch are you guys saying to remove the switch from the transmission and cleaning it or just clean the contacts. to remove the switch it looks like i will have to pull the pipe to get at it. is that correct?
Old Jan 2, 2007 | 10:31 PM
01vic99's Avatar
problem solved. I pulled the switch out and one of the contacts isnt making. thanks for all the suggestions.
Cole Hadden
Jun 15, 2025 09:05 AM
1000gade
Jul 16, 2015 10:48 AM
maxjung
Jul 15, 2015 11:59 PM
maxjung
Jul 14, 2015 12:29 PM
maxjung
Jul 13, 2015 05:11 PM
