More Clutch questions... 1986 TrailBoss 2x4
I have posted before about this clutch - I have looked around trying to find a cheaper one on ebay and been a day late everytime or its a performance... I was reading on here yesterday about pink/white/red springs and whatnot - is there a quick and dirty thing I can do to my clutch with out having it rebuilt? I have checked around and it will be like $250 to have that done.
its symptoms are when you accelerate it moves fine but then it revs to all and wont shift? I bought it like this so I dont actually know what normal is but 5mph top end seems wrong. I was told before its my primary... Do you think if I just replace the spring and belt it might do the trick? |
if its not shifting out most likely the spring or maybe the buttons are broke in the secondary clutch. best thing to do is pull off the cover and take a peak.maybe the belt is toast as well.
I am going to take a look at it hopefully this weekend - what are buttons?
Also, is there a website or something that explains how the clutch works? |
You can go to hellclicker. They show you how to take the rear clutch apart. T he ramp or helix rides up & down on the buttons . You will just have to take apart to be able to see how it works. I had to replace mine a while back .. It's not hard
This is the way I checked mine. Jack the atv up . With the clutch cover off ( BE CAREFUL DON'T GET INTO THE CLUTCH ) Set it in low & give it gas & watch the front & rear when the belt starts to climb the front clutch it will start to go down in the rear . If it doesn't go down in the rear it's the buttons.
i agree check the rear clutch spring and buttons,also check the helix for wear.you can get new buttons from www.denniskirk.com
