Starter goes "CLICK"...then nothing.
Old Jan 5, 2007 | 04:27 PM
csbomb's Avatar
Default Starter goes "CLICK"...then nothing.
1998 Polaris Trail Boss 250
Battery is good.
Pressing the starter button all I hear is a "CLICK" and then nothing. Fires up great with the pull start (even at 20 degrees and sitting for a week) on the first pull.
I've only had this bugger for a little over a month, not real familiar with all the Polaris mechs and quirks.
Will a starter rebuild kit fix it? A new starter? Or just a starter drive? Of course, I'm sure a new starter and starter drive would get it going - but I'm looking to save some dough on this repair because I'm also replacing the rear swingarm (busted at the left side mount).
Old Jan 5, 2007 | 04:33 PM
scgmag325's Avatar
Are you positive that the battery is fine, because mine did that for a while and all I did was fill the battery with water and charge it up... then it worked great.
Old Jan 5, 2007 | 04:34 PM
crashby's Avatar
Is the starter spinning? If its not then check the connections. It could also be a bad solenoid.
Old Jan 5, 2007 | 04:41 PM
csbomb's Avatar
The battery is good, I'll double check it again with the VM though.
The starter does not spin at all. All I get when I press the start button is a "CLICK" and that's it. Starts like a gem on the first pull of the pull start though.
Somebody on another forum recommended checking the starter relay before anything else (short across the wire bolts to see if it turns over).
Old Jan 5, 2007 | 04:49 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i would by pass the relay to see if it starts the way you described to see if indeed its starter.
Old Jan 5, 2007 | 05:16 PM
Cmott426's Avatar
The click is the solenoid. It is located near the battery.
If jumping the solenoid does nothing then it is the starter brushes.
You can replace them with this Starter rebuild kit or clean the armature and brushes. On mine the brushes where rusted to the holder and would not advance when they wore down. I cleaned them and now it works great.
Old Jan 5, 2007 | 05:52 PM
NBsportsman's Avatar
I agree with Cmott426 that it is most likely the brushes. Mine was doing the same thing last spring and one brush was sticking. Cleaned it up and was good to go.......
Old Jan 5, 2007 | 07:57 PM
squeege's Avatar
If ya look real close you can prolly find the root cause of the problem......it should be spelled out on the side of your quad somewhere[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jan 5, 2007 | 08:06 PM
Willb's Avatar
Brush is stuck just get the rebuild kit. You can find them on ebay cheaper sometimes just search polaris starter.
Old Jan 5, 2007 | 08:29 PM
BassBlaster's Avatar
Before you do anything that costs money, check to make sure your connections are tight. My Scrambler did the exact same thing and it was just a loose connection at the battery terminal. It just tightens up with a Philips screwdriver.
