Brake reservoir leaking
Old Jan 15, 2007 | 01:05 PM
DDirk's Avatar
Default Brake reservoir leaking
For the last year my brake reservoir has been leaking. Causing all the paint to bubble on the reservoir and leaking onto the handle bars. Tried re-seating the lid but still seems to leak.
Has anyone else had this problem? Will a new lid or gasket fix it? Or do I need to replace the reservoir? Maybe a common problem with 2005s?
And does anyone know if I can use just normal automotive brake fluid in my sportsman?
Old Jan 15, 2007 | 02:08 PM
SAshton's Avatar
mine leaked and I applied blue RTV silicon sealant on the cover and no problems or leaks(be careful and u only need a very small bead) u dont want to make a mess and get into master cyl. Some will disagree with silicon but it works and i have no problems.
Old Jan 15, 2007 | 02:11 PM
sandjunkie200738's Avatar
that sounds like some thing i would try.. dot brake fluid is all i have ever used . i am sure its all right to use on your 500 sportsman.. good luck
Old Jan 15, 2007 | 09:23 PM
hikuntryslim's Avatar
mine did the same thing on my 05 trailblazer . , ended up buying new cover n seal [ could nt buy just a new seal from the popo dealer ]
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:57 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:48 PM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
