'05 Trailblazer Starting Problem
Old Jan 16, 2007 | 10:29 AM
rottweilerz's Avatar
Default '05 Trailblazer Starting Problem
I have an '05 Trailblazer that has had no problems since day one. It started fine up to a month ago and now the electirc start does nothing. I checked the batter twice and it's showing being fully charged. The pull start works on the first time and then runs like a champ. I have checked all the connections I could get to and nothing seemed loose. For the most part this quad has sat alot over the past year, but always started regulary. I was wondering if I should just change the battery anyway?
Old Jan 16, 2007 | 06:46 PM
ftwflh's Avatar
The starter clutch has stuck or rust up.Take it out and soak it in some pentitrating oil and free it up.It should be ok after that.
Old Jan 16, 2007 | 08:26 PM
Thanks for the response.
My guess would be stuck...now where to find the starter clutch on the bike?
Old Jan 16, 2007 | 11:17 PM
ftwflh's Avatar
Take the recoil housing off and it is in there behind the flywheel
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
generalpops
Jun 3, 2015 08:25 PM
FourWheelOverTwo
May 31, 2015 07:26 PM
1000gade
May 27, 2015 12:37 PM
