Are 2006 SP500 tires/wheels compatible with 2004 SP700?
Old Jan 23, 2007 | 04:09 PM
WAATV's Avatar
Default Are 2006 SP500 tires/wheels compatible with 2004 SP700?
(Originally misposted in the "Tires" forum, sorry.)
The tires are only one inch larger (26 vs. 25 inches), so I doubt there would be a problem due to diameter. However, I don't know if the 2006 wheels will fit the 2005 machine. Are the lug nut patterns the same? Are the 2006 wheels compatible with the 2004 brakes/axles/etc.?
Thanks!
Old Jan 23, 2007 | 05:12 PM
crashby's Avatar
i am pretty sure they will work
Old Jan 23, 2007 | 09:08 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
yes they will work. the lugs are all the same on the sportsmans. the only thing it will effect is the speedo a little but not much.
Old Jan 24, 2007 | 12:33 AM
WAATV's Avatar
By my calculations, about four percent. I doubt the speedometer is +/- 5% accurate anyway!
Thanks!
Old Jan 24, 2007 | 08:07 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
i know when i put my 26" tires on the sportsman 450(stock 25") it changed the speedometer by about 5 mph. now my friends bf 750 he went from 25 to 27" and it lost more then that not sure how much though.
Old Jan 24, 2007 | 09:00 AM
upnort's Avatar
The Sportsman lug pattern is a 4-156 pattern. Do not know about the sport machines or the newer chinese polarises i.e. Hawkeye.
Old Jan 24, 2007 | 11:42 AM
BigDog800EFI's Avatar
I f the 04 has outboard hubs, the new polaris aluminum rims with the solid center will not work without spacers. If you are refering to the steel or anyother aluminum wheel besides the polaris brand they will work.
akguy31
Aug 31, 2019 04:34 AM
2many2ride
Sep 27, 2015 04:35 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Bernhard
Sep 25, 2015 12:45 PM
Sw00p
Sep 24, 2015 02:50 PM
