400sp clutch kit ?
Old Feb 4, 2007 | 09:31 AM
ftwflh's Avatar
Default 400sp clutch kit ?
I have run aaen products and they do a good job.On your 400 (I had an older 425) I got a good gain from changing the primary spring to a Polaris white and an Aaen blue secondary spring.
Old Feb 4, 2007 | 11:12 AM
HotRod35's Avatar
Tanks for the reply Ftwflh I was just woundering about the stuff from aaenperformance they had a kit it did;nt really say what it consited of so i called the outherday to see what came with it the lady I spoke to was very nice she told me it came with a spring for the primary and diffrant weights and for the secondary a diffrant helix, and spring I was wanting to know more but thhe guy I neeed to talke to she said was busy but if I called back someother time he could explain it to me better. Oh ya another thing was I kinda liked the price to about 95$ shiped.
Old Feb 4, 2007 | 12:39 PM
onesavage's Avatar
i just went to the aaen we site and found a pipe for my 400 sportsman and would like to get more info they also have a kit for a trailblazer to up it to 38hp(wow) but i could not get a phone #### ... iam realy interested does anybody know how to get ahold of them,like i said it was not on the web page or i just could not find it .. anybody
Old Feb 4, 2007 | 01:44 PM
HotRod35's Avatar
I called the otherday but the guy I needed to talke to was busy just have'nt called back phone no# 1-262-552-8981 or 1-262-552-9410. I was going to ask about their power shift kits they had on the website if you find anything out about their kits or stuff let me know ok.
Old Feb 4, 2007 | 02:09 PM
  #15
onesavage's Avatar
i will call tomorow if i rember ... i want to check outh e the pipe, and clutch kit.. i still think epi is way to go i am just waiting on a few more leads... thanks for the#####
Old Feb 4, 2007 | 06:08 PM
  #16
wayout's Avatar
guys i believe aaen is blowing smoke up your as.. ask him if it doesn't work can you get your money back,heelclicker will,wayout,out................................... ..
Old Feb 4, 2007 | 06:20 PM
  #17
onesavage's Avatar
thats funny i asked heelclicker if i could get my monney back if i was not satisfied.. he said no.. but epi also said we will not return a installed item...i believe a epi will better benifit a 400 single cyl eng than any other kit... just my 2 cents .. i also believe a h/c will out performe on the bigger twins.. i feel that a 400 needs more tuneing to get up to par, jet kit, k&n ,exaust,over rev cdi box, even a ported head if i get that ambitious.. its there it just needs to be tuned and tweaked.. i think the key to a 400 is rpms, all though i could just be a dummy.. POLARIS THE WAY OUT!!!!
Old Feb 4, 2007 | 06:36 PM
  #18
ftwflh's Avatar
I can tell you from experiance that the 400aka 425 just needs some minor clutch work(no need for a kit) a K&N filter and a good flowing exhaust and it will run with any of them.
I personally dont care for EPI kits.They have a few good springs to choose from.
HeelClicker is a very god set up but takes time to dial in.
Aaens kits are ok if you NEED the helex and springs as is HPD.Hotseat is good too but I dont like the way they set up the weights and the helex they recomend.
No complaints on Dalton Industreis other than they are a bit pricey.
Actually the BEST thing anyone can do with a non EFI is put in a TEAM roller secondary set up from HPD for their machine and go with a spring and weight change to get the wanted power range.
Old Feb 4, 2007 | 06:42 PM
  #19
onesavage's Avatar
i am wondering why the aaen kit is only $99.00 (just checked) and the epi is 179.00 , they change the same parts ,weights springs and helix ...
Old Feb 5, 2007 | 07:41 AM
  #20
wayout's Avatar
wayout,here,you may be right onesavage, keep in mind,i bought mine in 2004,things could of changed since then,sounds like they have,, i bought mine just for pulling power,also so i wouldn't have to use low gear as much,,if i wanted more power, i would have bought a bigger atv.....wayout,out..........................
