2001 polaris 500 4x4 scrambler rear brake problem
Old Feb 4, 2007 | 12:04 AM
bullseye9's Avatar
Default 2001 polaris 500 4x4 scrambler rear brake problem
I have no compression on my brake lever. I bought it used and he said the brakes have not worked in about 6 months. The pads were ground down to nothing, so I replaced them. The caliper seem good, the piston reset with no problem. I just can not get any pressure out of the foot lever.
Old Feb 4, 2007 | 12:28 AM
trailblazermudrunner's Avatar
have u tryed puttin all new fluids in the resovor?? and are there any holes or anyting in the lines??
Old Feb 4, 2007 | 12:32 AM
03scrambler500's Avatar
also try to bleed them
Jason
Old Feb 4, 2007 | 12:34 AM
scramblerXrated's Avatar
ask any gen 3 owner, that rear brake has always been a problem. they work new but do not last. do a search in the forums and youll see. most of us just learn to deal with it and learn to ride with out it.
the rear brake still werks with the hand brake. or you can go with the split brake kit from hot seat. this will allow you to control the rears with your right hand.
i have this kit and find that i rarely use it anyways.
X
Old Feb 4, 2007 | 08:52 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
for sure the rear brake pedal is almost useless after a short while. i never even use them on either of our machines.
Old Feb 4, 2007 | 05:30 PM
bullseye9's Avatar
There are no leaks. The caliper seems ok just lack of compression. I am guessing the master cylinder or the seals are bad. Where exactly is the problem everyone is having. Is it in the master cylinder or caliper? At the moment this is new to me, and like always eventully I will figure it out. But right now it is really frustrating
Old Feb 4, 2007 | 05:39 PM
Just try to bleed them, mine will work fine for a while then do this same thing i bleed them and they are good to go again
Jason
Old Feb 4, 2007 | 06:18 PM
the problem is most always the rear master cylinder.
being exposed to all the dirt i think is what makes the seals go bad on it.
X
Old Feb 4, 2007 | 06:35 PM
Kerbbirds's Avatar
Bleed them with the lid off of the resevoir, it took alot to get mine working again. I step on them 4or 5 times everytime I ride and havent had any problem since.
Old Feb 4, 2007 | 06:43 PM
ftwflh's Avatar
DITTo you have to bleed them with the cap OFF for some reason
