CVT intake
Old Feb 21, 2007 | 05:10 PM
MNScrambler's Avatar
Default CVT intake
Has anyone come up with a good way to keep water and mud out of the CVT intake snorkle? I was thinking about trying to put a piece of Outerwears prefilter material over the opening. Would this restrict the airflow too much and cause the clutch temps to heat up too much. I don't have any experience with this material. Thanks.
Old Feb 21, 2007 | 09:11 PM
67cam's Avatar
Default CVT intake
i had a problem with mine. every time i would go through water or mud (not deep at all) at a decent speed my cvt would fill up with water. so i went to home depot and made a new snorkel out of pvc for the exhaust, and for the intake i used a shop vac hose plumed up by the handle bars. it worked like a charm, i can plow threw the stuff as fast as i want without a slip. for some reason i haven't been able to figure out how to post pics on this website but if you pm me with your email address i will send you some pics. it was real simple, and cost about 10 bucks.
Old Feb 22, 2007 | 08:49 AM
Scrambler00's Avatar
Default CVT intake
i did a make shift snorkel for the cvt exhaust... i thought i was the only one who liked mudding on a scrambler. 67cam how did you mount the hose you bought to the intake? from the top of the stock one, or right from the clutch case?
Old Feb 22, 2007 | 10:54 PM
67cam's Avatar
Default CVT intake
i went right off of the stock snorkel up along side the gas tank, and up under the handle bars. i shaped the the vac hose into an oval so it would fit under the plastics. i was a little concerned with the cvt overheating with the snorkel extended like this, i kept a close i on it all last season, and pulled the cover this fall to check the belt tension and it didn't over heat one bit.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Sassinm1
Sep 30, 2015 04:23 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
Ridgebackguy86
Sep 19, 2015 12:48 PM
