1995 polaris sportsman 400 4x4
Old Mar 27, 2007 | 05:57 PM
flyersfan's Avatar
Default 1995 polaris sportsman 400 4x4
Hi all my first time here..hope someone can help somehow....I am new to atv's, bought it 2 weeks ago brought it in garage and started working on it...cleaning..gettin rid of rust..change bulbs...ect....i removed the seat..i could smell gas...i removed the filter housing...I noticed a loose fuel line..it comes from underneath the carburator...halfway there is a....sorta looks like a filter size of a nickel..then a fuel line that goes from there to .... i have no clue..I asked the previous owner..and he's as dumb as I am on the issue..I had bought new fuel lines to replace in case they were old..since its a 1995..I have the hayne's repair and maintenance manual for it but it doesn't show any fuel line configurations..
all help would be greatly appreciated
Thanks in advance,
Flyersfan
Old Mar 27, 2007 | 06:05 PM
vmaxfrank's Avatar
My first guess is the fuel was left on and the bowls flooded. Both my sportsman and scrambler with leak if the fuel is left on. As far as the line, my first guess is it's just a vent from the carb, but I will check mine and reply back.
Old Mar 27, 2007 | 06:32 PM
flyersfan's Avatar
thanks...like I said im a dummy when it comes to atv's...uhhhh how do i shut off the gas?
Old Mar 27, 2007 | 06:47 PM
flyersfan's Avatar
If it helps at all the end of the hose that isnt connected is brownish..cannot see thru it..
Old Mar 27, 2007 | 06:56 PM
drlang's Avatar
If it's below the carb coming from the carb and really small that is a vent. The nickel sized thing is a check valve. Doc
Old Mar 27, 2007 | 07:12 PM
flyersfan's Avatar
ok so it doesn't connect to anything.....why is it leaking?
Old Mar 27, 2007 | 07:35 PM
flyersfan's Avatar
the hose with the check valve is about 1 foot long
Old Mar 27, 2007 | 07:46 PM
87mac's Avatar
it could be a overflow hose
Old Mar 27, 2007 | 08:04 PM
flyersfan's Avatar
I took a few pics...can i post them on here....theres also a hose that comes from the side of the carb...the hose is clearer than other one
Old Mar 27, 2007 | 08:15 PM
87mac's Avatar
what do you meen clearer
