mag 330
Old May 23, 2007 | 01:15 PM
Hvacman's Avatar
Default mag 330
I just looking at a mag 330 05 I am 250 lbs 6 ft tall will that be too small for me
Old May 23, 2007 | 07:33 PM
ftwflh's Avatar
Default mag 330
If you arent wanting a speed demon it will fit you ok.But you may want to reclutch it to get more power where you need it.
I have a 330 TB and it carrys my 230lbs just fine after I tuned the clutches.
Old May 23, 2007 | 08:15 PM
Hvacman's Avatar
Default mag 330
what clutches sould I uses
Old May 24, 2007 | 10:51 PM
ftwflh's Avatar
Default mag 330
Go with a Polaris white primary spring to start off with.If that doesnt suit you get an EPI pink and an Aaen blue secondary spring.
Old May 25, 2007 | 12:52 AM
Ipaq's Avatar
Default mag 330
The Magnum 330 is one of the best cost effective Polaris ATV.
No clutch modification is needed!!!
As is, it will carry your weight and 100 lbs equipments. This is a very low maintenance ATV with very good fuel consumption.
Not a very fast ATV, but if you are looking for "start and ride" this is the one.
Old May 25, 2007 | 08:06 AM
ftwflh's Avatar
Default mag 330
<div class="FTQUOTE"><begin quote>Originally posted by: Ipaq
Not a very fast ATV, but if you are looking for "start and ride" this is the one.</end quote></div>
I agree with everything you say but the clutching issue.It comes from the factory under clutched with a lot of power hidden.I have tuned my clutch withy a tach to get good lowend and great mid range power.
