Engine rebuild of my xplorer 400
Old Jun 22, 2007 | 03:08 AM
  #21
truckermatt's Avatar
Default Engine rebuild of my xplorer 400
Ok. well i put everything back together, and tried to start the atv, and it wont start, it just turns over,
how do i know if i have a good spark? what needs replacing if i dont? i tried hold the spark plug against the engine to see a spark, but i got shocked when i held the cable.... ouch!!
any other tips to look for,
the fuel is on, the air box/filter/ the carb, new spark plug,........
Old Jun 22, 2007 | 10:59 PM
  #22
thanks, i did in fact smooth up the head the best i could before i reinstalled it. well, there was no collant leaking from the head, and actually the head gasket was in very nice shape.... (but i did replace it anyways).... i am just curious as to why it wont start now.... it just turns over like it did before.... but now is has more compression though. i took the carb apart and cleaned every thing and replace the jets, and put the air mixture screw 1.5 turn out per the manual.... and the needle is on the 3rd clip just like the stock setting say....
DO you think change the needle height would make a difference? what does it do?
Old Jun 23, 2007 | 10:57 PM
  #23
well i basically narrowed my starting problem to a fuel problem..... does anyone know what on the carb would be prevent the fuel from getting into the firing chamber by the spark plug? because the quad will fire when i spray some fluid in the park plug hole?
Old Jun 24, 2007 | 07:58 PM
  #24
does anyone have a suggestion, or should i take it to the shop....
Old Jun 25, 2007 | 10:16 PM
  #25
leonardwil's Avatar
if you got shocked you have spark. get a new plug.did you check to see if you are geting gas to the carb.i had to replace mine it was coming apart on the inside and stoping fuel flo.
Old Jun 28, 2007 | 12:14 AM
  #26
leonardwil's Avatar
I was saying to check your fuel line to make sure it was not stoped up
Old Jun 28, 2007 | 02:56 AM
  #27
thanks for everyones helps
the atv has been sold
slowgsxr97
Mar 18, 2022 03:40 AM
kelleycully
Sep 15, 2016 02:57 AM
Big bousse
Sep 26, 2015 10:42 AM
ghost civic
Jul 27, 2015 03:15 AM
hondarider1234
Jul 21, 2015 11:53 PM
