Sportsman 500 Problem
Old Jul 18, 2007 | 12:26 AM
Scott267839's Avatar
Default Sportsman 500 Problem
check exhaust lobe on cam or have dealer check it. It is easy to check. I neighbor just bought a used '98 500 and found the exhaust lobe completly worn down.
Old Jul 18, 2007 | 12:30 AM
03scrambler500's Avatar
thats what i think too
Old Jul 18, 2007 | 12:43 AM
YIYO's Avatar
It seems like you have a bad CDI box ,This things are like the ignition modules on cars ,they run for a wile and once they heat up they shut doun.the engine with a worn out cam will not run, because there is no air coming in or out. Wich means no combustion. Have your deler check the CDI. And yes have them check the wireing harnes.
Old Jul 19, 2007 | 11:07 AM
hobbles's Avatar
Mornin Big_Henry
Polaris had a problem with the coil wire shortin out under the front of the gas on 05's,, just a thought,,,
Old Jul 19, 2007 | 04:50 PM
  #15
cweg1's Avatar
Hey Henry Polaris issued a bulliten for "pinched coil wire" on 500 Sportsmans. Make sure you check that.
Old Aug 12, 2007 | 10:02 PM
  #16
RDZone's Avatar
Henry, Have you figured your problem out yet? Was it the cam lobes? I am new to this forum and had the same thing happen. The lobes weren't worn but the lifters (valves) needed to be adjusted and one of my stator bobbins was loose.
Old Dec 23, 2007 | 04:33 PM
  #17
reedr125's Avatar
Definetly a cdi box. Things like exhaust lobes and internal parts don't usually let go with out warning. I recommend upgrading it from the stock one. Using jumper cables, and either are just band aid ways of getting things started. If its truly fixed it should start on its own as long as you have a charge in the battery.
Old Nov 14, 2008 | 02:45 PM
  #18
SporTex's Avatar
Default Sportsman 500 Problem"></title><script src=
<div class="FTQUOTE"><begin quote>Originally posted by: Deerkiller
I had a similar problem last summer, Idleing then just quit. I changed the plug checked fuel, no spark and i figured it was a coil so i took it to the dealer.
They told me a very common problem with the 500's ,not sure if your year is included but, the spark plug wire is routed under the tank and pinches. The wire is seperate from the coil, cost me about $12.00. fine since then.
Deer killer</end quote></div>
Mine turns over but won't start ( no spark at all ) Did you get a longer wire and
re-route it?
Old Nov 14, 2008 | 05:16 PM
  #19
Deerkiller's Avatar
Wow, old post.
Supposedly it was a warranty replacement but the dealer charged me.
I think they put a stock plug wire on of standard length and rerouted it so as not to get pinched.
Haven't had that problem since.
Good luck
Deerkiller
Old Nov 14, 2008 | 05:34 PM
  #20
SporTex's Avatar
Checked mine, not pinched anywhere. Guess I'm on to coil, stator, or CDI.
