hi/low range.... please explain
Old Jul 15, 2007 | 05:04 PM
brutus450's Avatar
Default hi/low range.... please explain
I dont think the amount of time in low hurts at all but it how you use it like STEN suggests
but one thing is, I dont think low puts more hours on
Old Jul 15, 2007 | 05:52 PM
I think 10-15 mph is about where I would top out on the speed in low. It doesn't hurt the quad to ride in low all day long. If you are going to be under 10 mph you SHOULD keep it in low. It (as has been said) makes for a longer lasting belt and I believe Polaris recommends keeping it in low for cooling purposes also.
Old Jul 15, 2007 | 06:00 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
<div class="FTQUOTE"><begin quote>Originally posted by: brutus450
but one thing is, I dont think low puts more hours on</end quote></div>
what i ment was that being in low your going alot slower there running the engine longer to get there. my bad for not explaining lol.(i also here from the wife)[img]i/expressions/face-icon-small-happy.gif[/img]
Old Jul 15, 2007 | 07:07 PM
buckaroo50's Avatar
Part of the reason you have to use the low range so much is because your 26" tires have changed your gearing. Your low gear is close to what second gear was with 25" tires,
Old Jul 15, 2007 | 07:27 PM
  #15
kas379's Avatar
The more technical and slower the terrain, then you should use low more often, especially if you're going to need to keep it in low for a while in order to get you through the technical terrain. You can leave it in high even if it's only for a short period of time, but as most here agreed, using low in technical terrain is better for the belt etc.
Old Jul 16, 2007 | 08:35 PM
  #16
oinkjackson's Avatar
i go up tp about 15 in low......although the manual says dont exceed 7...it seems 7 is to slow to me?
Old Jul 16, 2007 | 08:46 PM
  #17
RticKwad's Avatar
Runs Stealth!
Thanks for "Eduma-cating" me on the Low usage. Okay here is another while the
thread is still active. Should you put your quad in LOW gear for steep "declining
hills"? I know about uphill but this is for downhilling. A guy we went riding with
recommended doing it, I can see now with going slow during the decline, less
belt wear, protections against throttle mishaps etc. - Make sense but not sure
with alot of these bikes using "engine breaking" features (not mine of course).
Thanks for all the good info., Stendori we knew what you meant buddy!
R'
Old Jul 16, 2007 | 08:47 PM
  #18
RticKwad's Avatar
Runs Stealth!
What I meant to say is "how can the pupil teach the master"? LOL
R'
Old Jul 16, 2007 | 09:08 PM
  #19
SCRAMMYTODD's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: buckaroo50
Part of the reason you have to use the low range so much is because your 26" tires have changed your gearing. Your low gear is close to what second gear was with 25" tires,</end quote></div>
Polaris does not run normal gears like you are describing. There is a Constant Velocity Transmisson (CVT) that feeds a seperate transmission with the high/low/reverse/park/neutral functions.
What POLARISBEAR500 is wondering is when to use LOW and when to use HIGH range. The best way to utilize high in more conditions is with a clutch kit. Something that will engage the belt harder and faster.
Old Jul 17, 2007 | 02:07 AM
  #20
TLC's Avatar
TLC
Pick any spring color you want to change the engagement RPM. You say the Vinson feels the same in High or low range? than whats the point? it must be loosing in another area. Are you faster on the top end and acceleration in high range?
MikeyBoyesq
Aug 10, 2015 11:11 AM
toonces
Aug 6, 2015 10:46 AM
Polarisman1123
Aug 3, 2015 02:08 PM
ltrmc02
Jul 22, 2015 04:50 AM
Bayou3004x4
May 10, 2001 11:08 AM
