HELP
Old Jul 25, 2007 | 11:00 PM
KBOB5's Avatar
Default HELP
Hey guys I've been having heating issuses with my 05 500, so i would like to install a switch for my fan so i can turn it on manually. is there a specific spot where i should splice the switch in?
Old Jul 25, 2007 | 11:28 PM
SCRAMMYTODD's Avatar
Default HELP
If everthing is working correctly, you shouldn't need to worry about manually turning on your fan. What is the issue you are having??
Old Jul 25, 2007 | 11:30 PM
duffus's Avatar
Default HELP
the plug is located under the front "hood" (just beneat the pod). It is a twin wire plug> i'll try to get the wire colors when I look at mine next. But scrammtodd says it right-- you shouldn't need the switch. There must be another problem..... can you tell us more about it?
Old Jul 25, 2007 | 11:47 PM
Default HELP
I found that when I put the coolant temp gauge in, I never worry about how hot my bike is. Just a glance down and I know exactly how hot it is.
Old Jul 26, 2007 | 11:05 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
Default HELP
make sure your radiator isnt the main issue of the heating problem of being plugged from back as well as from front.
