need help with 330 magnum
Old Aug 6, 2007 | 12:12 PM
cgarza's Avatar
Default need help with 330 magnum
My boy has the 330 magnum a 2004. The other day he was going through some water and accidently cut off the gas, in doing so the motor died on him sucking in some water. after i pulled him home, we drained the oil and replaced it, and the water where the belts are was drained. the motor will start right away, but will just idle, as we attempt to give gas it dies. What should we do, or what can we do?
Old Aug 6, 2007 | 06:39 PM
RobRuf's Avatar
I would change all the fluids and filters. Check the carb, and anywhere gas is. Also while your at it change the air filter. When you change the oil you'll know if there is water in there so that will solve that part. Might as well check under the hood (remove box in front) and check "computer" for water or wetness...
Old Aug 6, 2007 | 09:18 PM
samk's Avatar
How deep was the water? Is it possible that the air filter is soaked & the air box is holding water? If the air filter is soaked, it could be allowing enough air through to idle but sucking water off the filter when the air flow is increased.
Just throwing things out there.
Old Aug 6, 2007 | 11:21 PM
ftwflh's Avatar
take the carb off and clean the jets.Sounds like you got water in the main jet.But clean both to be on the safe side
Old Aug 7, 2007 | 11:36 AM
cgarza's Avatar
Thanks for the help guys. Did the carb cleaning, the air filter was dry, change the oil. We got it going last night, again thanks.
Gwolf228
Feb 18, 2017 01:36 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Sep 9, 2015 06:57 AM
Dan Newberry
Aug 30, 2015 09:42 AM
