Magnum 500 has no GO!!!
Old Aug 21, 2007 | 08:39 PM
PKrRiverRiders's Avatar
Default Magnum 500 has no GO!!!
I have a Magnum 500. 2001. It seems to be shifting into gears..low, high, reverse.
But when I give it the gas it grinds and it won't go. I can fix it but don't want to disassemble the whole thing to find out it is just some simple plastic part. Any help with where I should begin looking for the problem would be appreciated.....
Old Aug 22, 2007 | 12:10 AM
ftwflh's Avatar
Start by checking the bell cranks on the tranny where the shift rods hook to.They tend to strip out.If these arent bad it is time to tear down the tranny for new shift forks and chains and maybe a gear or two.It is harder to pull the tranny out than to repair whats inside
Old Aug 22, 2007 | 04:50 PM
Thanks for your response. I will check those first. It helps just knowing where to look first.
Old Aug 22, 2007 | 09:09 PM
xplorerman's Avatar
Also try ajusting the shift rod's that's what my frend's problem was
Gwolf228
Feb 18, 2017 01:36 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Sep 9, 2015 06:57 AM
Dan Newberry
Aug 30, 2015 09:42 AM
